Could This be a Bug??
My first attempt at upgrading to 1.8.9-2 failed but with the revised version that came out a couple weeks later installed without any problems. Happy camper here but when I started to work on my first project I noticed that the Process Console was not showing while a process was running! I've looked all over for it and reinstalled PI several times but it just doesn't show up anywhere. Has anybody heard of this issue before? My other thought was that I'm just loosing my mind?
  • Well..the process console, by default, is not "sticky" and only pops out when a process is running However, if you are using multiple monitors or have so other graphics issue- this might be an issue.
    I would force it to pop out by clicking on the Process Console tab (make it visible if it is not) and make it sticky to be certain that is working. Then you can experiment with the fly-out behavior.
  • Thank you Adam but I guess my issue is that I can't make the Process Console visible! How do I do that? I have gone along the top Menu bar to "View" and selected "Process Console" but that does nothing also "Ctrl"  "Alt" "C" and that also does nothing.
    1920 x 1080 - 311K
  • Thanks Adam, I may have figured out what was happening!!
    Cheers!!
    Gregg
