Hi all,I am trying to process my third image combining two capture sessions (M51 120x60s +180x30s)) with dedicated bias, darks, flats. WBPP (with keywords grouping) worked fine with cosmetic correction. I had to crop because the two sessions were not framed exactly the same (oops). I had to remove some gradient with DBE then SPCC, BXT, NXT and here comes my problem. I am trying to get both a luminous galaxy with some (but not too much) colors, without a burned core. So I tried using MaskedStretch. It works well but at the end I always get some patchy background with some red flavour somewhere, it's not really strong but really not good. I clearly noticed that if I want to push maskedstretch too much (200 iterations) with an increase of the stretched background image the patchy background appears (with reddish areas) more and more. I tried to interleave some HT to darken the background a little bit before applying the maskedstretch but if I go too far maskedstretch sends an error message (too dark image). I have to add that I tried to play a little bit with color saturation and curves to bring some colour in the galaxy at the linear stage.
The final result is not a disaster but I am willing to get the best of what I can do from my data.
Is there something wrong in my workflow or what should I take care of to avoid this emergence of the background at the end? Thanks in advance, Frederic
:)" style="box-sizing: border-box; border-style: none; max-width: none; height: 22px; vertical-align: text-bottom; width: 22px; background: url("styles/default/xenforo/smilies/emojione/sprite_sheet_emojione.png") 0px 0px / 100% no-repeat rgb(254, 254, 254); color: rgb(20, 20, 20); font-family: Nunito, "Helvetica Neue", Helvetica, Roboto, Oxygen, Ubuntu, Cantarell, "Fira Sans", "Droid Sans", sans-serif; font-size: 15px;" />
