Adding more data WBPP script
Hi,
Apologies if this has been covered before but I cant find anything on this.
I want to see how my data is progressing. I processed my subs through WBPP script, and got master light frames to process further. I now have more data, the Cache has not been erased and I haven't processed another target in the meanwhile.
Do I just have to add the extra subs from each filter to WBPP script and then press run again? Will all master light files be overridden with the updated subs etc? Anything else I need to do?
thanjks
Matt
  • Hi Matt,
    If you still have the cached WBPP session... yes! You can add the new data. What should happen is that it will only do the preprocessing  on the new data. (Calibration and stuff). When it gets to the point of ImageIntegration, WBPP should integrate all of the data together including the new data. You will end up with a new MasterLight (WBPP will never erase anything..it just makes new versions of images).
    Nothing more you need to do I think.
  • Thanks Adam.
