Error with SPCC
Hi Adam.  Was attempting to use SPCC on an image I'd just completed Image Solver with to get an astrometric solution; I'll note that I needed to use the EDR3 Catalog to get a solution.  I received the error below when I attempted to use SPCC on the image.  I've never encountered this problem before: any ideas as to what's going on here?  Thanks - Reggie Jones
*** Error: Invalid Gaia DR3/SP XPSD server execution: Couldn't retrieve a valid spectrum wavelength table.
  • Hi Reggie,
    This means your GAIA catalogs are not setup.
    The fact that you mentioned EDR3 is a red flag. This is no longer (a useful) part of the GAIA catalogs that interests us. DR3 and DR3/SP are the only ones of interest. The error is saying you have not correctly set this up because either you did not load the DR3/SP files correctly in the GAIA process... or you literally do not have them. I think it is the former (and a common error).
    Can you confirm (with screenshots) you did set up the GAIA process correctly?
    There is a chance, if you did, that one more of the files is corrupted..but I think the error is different in this case.
  • Thanks Adam; I probably should have added that I have a newer iMac and the programs from my older iMac were migrated to this new iMac - probably caused an issue.  I'll go back and set the GAIA files up correctly for this new iMac and see what happens from there.
