I am using calibrated data downloaded from Telescope Live am trying to process them
in the order as described in the videos about Local Normalization.1. Cosmetic Correction
2. Registration
3. Local Normalization
4. Image Integration
When performing Image Integration there are certain warnings that come up stating that the PSF and Noise calculations are being performed with non-raw data and that the results may not be accurate.
I assume that the reason for these warnings is that the entries needed in the fits header are missing due to the calibration not being done in PI
If the issue is actually that PI didn't calibrate the subs, is there a process that will add the required fits header entries... PSFFLX00, PSFMFP00, PSFNST00 and such, before doing Cosmetic Correction?
Miguel 8-)
