WBPP keyword help
I have some images to stack with 2 different cooling temperatures. Thats easy enough to separate with the keyword SET-TEMP. but then WBPP doesn't want to flat field the images. How do I calibrate an image with different temp darks but 1 set of flats?
  • I still believe the easiest way to do this is separate the data into folders. I just makes life very easy.
    Put the lights and darks of one temperature into a folder called "Data_Minus25" (or whatever).
    Put the lights and darks of the temperature into a folder called "Data_Minus30" (or whatever)
    Do not put the flats in either folder... this way they will be common to both.
    Do not put the darks for the flats in either folder.
    Using the KEYWORD "DATA" and set it for preprocessing.
    This configuration should do what you want. You can share some screenshots (using the diagnostics button).
