Before SPCC I was able to use PCC without any problems, now I have problems when trying to use SPCC. I have downloaded to "Whole Universe" of DR3 and SP star catalogs and have instructed Gaia as to where they are on my "D" drive. The image I am using is in Linear format. The RA and DEC appear in the FITS Header and are correct.When I use the image solver I can see in the Pixinsight info pane it going through all 16(?) of the catalogs and then I end up with this.....
"*** Error: Found too few stars. The magnitude filter could be too strict, or the catalog server could be malfunctioning and then ultimately this ...... *** Error: Unable to plate solve image: Alignment failed.
When I try to use SPCC I get this error message ..
*** Error: ZLib compression: Failed to uncompress subblock data (offset=0 usize=6144 csize=5235) and then of course this
*** Error: No catalog stars found
The same image will work in PPC and when I sent the same image to a friend of mine, he is able to run it in SPCC so it doesn't seem to be the image itself.
Does anybody have any ideas on how to resolve this?
Gregg
