At the beginning of my time using PixInsight (4 years ago), I use to calibrate my master data using the following steps:
1) Integrate bias in a master bias
2) Calibrate and optimize each dark with master bias (following a recipe from a web site)
3) Integrate each calibrated dark in a master dark
4) Delete original bias and dark files and store master bias and master dark for further use in reprocessing light data.
After see fundamentals videos about master files and calibration, I have a doubt. Which will be the correct use of the previous master bias and master dark described to apply on lights in order to reprocess images and make a correct calibration of them?
Because in my case, the order of producing a master darks wasn´t the recommended way, this master dark is usable? is it valid calibrate lights with master bias and this particular master dark?
Leonardo Arismendi
I will execute your recommendations.
