Edit filter name for WBPP
Hi,
First of all let me introduce myself, Padraig my name from Ireland ☘️
I’ve been using or more accurately playing around with Pixinsight for over a year.
I always felt I wasn’t getting the basics right so I took the plunge to join Adam’s course Fasttrack.
The issue I have, is I named some nights images L extreme instead of no filter, which I think WBPP will have a problem with different filter names.
Any help would be appreciated.
Ps: only a beginner
  • You can load the images in WBPP using the "Custom" button and assign the correct filter name. This is one way to do what you want.
    Can you give it a try?
  • Thanks,
    I’ll give that a go.
    Let you how I get on,
    Again, thanks
  • That worked, well kind of,
    The cosmetic correction failed for some reason, so I drove without it.
    I think I need to drizzle as well, and but not sure, i think i see a small bit of amp glow in the usual RHS.
    Overall I'm pleased with the outcome.
    thamks
  • That is odd concerning Cosmetic Correction.
    Please double check you selected the "Auto" method?
    Something might not be right about the template you set up.
  • Going through the process again, to reaffirm / improve,
    anyway, didn't I forget to tick "hot sigma"  under use auto detect.    :)
    still learning !!!
  • Ah ha... good.
