It appears to me that if you use the Master Dark method or the Defect List, you are restrained by the binning of the master dark or the master bias respectively, whereas for Auto Detect there is no such limitation. If so, then you would have to have a separate Cosmetic Correction template for each binning, and you would have to run BPP separately for each binning. Is this correct?
Alan
