Star Alignment Failure
Hi, recently I've been getting Star Alignment errors where only the reference file was being aligned (to itself, there no problems I assume). The error is always the same
"Unable to find an initial set of putative star pair matches"
When I look at the raw files, tracking looks good. The only thing the stars may not be 100% sharp. Could that be an issue? File is attached.
Thanks a lot!
Matt
6192 x 4128 - 15M
  • These stars are out-of-focus...and will not be detected by PSF fitting algorithms.
    This is certainly part of the problem.
    Under Star Detection I think you can force the "Compute PSFs" to never.
    This *might* help.. but focused stars probably the best solution.
  • edited September 2022
    thanks. Anything that can be done in post-processing to focus them?
    It's my camera, the live-view shows a lot of noise in the dark, and the stars are quivering around even when the telescope doesn't move. So very hard to focus, sometime it works, sometime it doesn't.
    thanks again
    Matt
    PS - yeah I tried Compute PSF = never. Didn't help.
