HDR Multiscale, Substitute script, background
Is there some technique to ensuring that the background still matches when you use a preview to isolate the HDR Multiscale, and then substitute it back in.
Sometimes (maybe most times) it does, but was doing M57 and struggling - getting a good rendition of the ring usually lightens the background slightly so when substituted back in, you can see the square.  I can fix it (sort of) by clipping the background overall afterwards, but that is not a good solution (notably the nearby bared galaxy is then reduced).
Using a larger preview seems to help as well, but I think by the time it is big enough to match the affect of the HDR process is reduced.
Is the answer trying to re-stretch the preview (after storing it) to match the original in some way with histogram?  Or is there another approach?
Linwood
  • Linwood,
    Here is my logic for most objects.
    1. HDRMT is used to compress the dynamic range of bright features.
    2. The background is not bright- it is not what HDRMT is working on (usefully)- especially if you are applying to a fraction of an image. Of course, if you apply to the entire image- everything will correlate.
    3. The use of a threshold mask (or selective mask) will limit where the HDRMT effect is visible and protect the original background.
    So I think the use of an appropriate mask is the best approach.
  • Thank you.  I'll give it a try. I was worried about a hard edge on the mask, but (sound of hand slapping forehead) I can just feather it with a convolution before applying the mask.
  • Linwood,
    You can feather the edge OR use a threshold type mask. That is only apply to pixels above a certain brightness- this will also protect the background- even if there are dark areas inside the object/area of interest.
