I am following along with the n3891 work flow. Because I did not have the flat or bias frames to set up Muir Denoise I went with NSG, then integrated with NSG settings. I did not have the pixelation AD had found in his work flow, causing him to backtrack using the other algo.
My route did result in differences and I had to use some different approaches then AD.
The most notable was that I had to use the object mask for decon. In AD's work flow he made the object mask but did not need to use it. With out the mask I had unsightly grouping of pixels in the background. I also noted that my results (decon) were not as effective in reducing the star size. Makes sense since so much more was masked.
I am now reworking the decon settings, trying to get better results.
