Sorry..I am a bit confused. I used all of the data provided. The H-alpha images were all 900 sec. The OIII and SI were all 1200sec. There are no 1200sec H-alpha.
Mike Selby provided both 900 second dark frames and 1200 second dark frames. So all of the data files are being used and calibrated for the OIII and the SII (please watch the WBPP section). Then later all of the files (both the 900 second and 1200 second files of OIII and SII) are integrated together after NSG. Proper normalization will give each frame appropriate weight so that the different exposure times are integrated properly. Look at the weights that NSG calculates. for example the 900 sec OIII files are roughly .75 in weight. This is the ratio of the exposure time.
I used exactly the same data set you have in hand.
