Went thru your tutorial on File organization. Noticed that the file Calibration File........Dark Master showed bin, Temp and seconds. When I process this Temp. is not included? Hope this comes to you with the screen shots.....My first time
If I understand the question, I think the difference you see is due to time....
I made the earlier videos back in 2018-2019... and things of course change through time (WBPP did not exist then... only BPP...and older version).
It is not critical for the temperature to appear in the file name (it is in the Header). In generally you will not likely be combining data for a single target that have camera temperatures at two different temperatures.
But if you do, you can always use a Keyword to make absolutely certain you are matching the correct darks with the correct data.
