Hi Adam:
your DBE use is a bit novel in your approach compared to others ...in that you seem to suggest (if I understood correctly) using whatever tolerance value is needed to achieve an adequate weighting for samples to get the full effect on the gradient....as long as your careful in placing samples and avoiding underlying stars etc. Others have suggested much small increases in tolerance to just include samples known to be in background areas..therefore small increases in tolerance maybe using 2.0 - 2.5 or so..warning not to go too high
so I find your approach intriguing, especially since in the past I have struggled with removing some tough gradients..maybe I wasn't achieving the best model with lower tolerance values, also maybe because I assumed most gradients in my flat calibrated images were additive in nature, especially in color images, but watching your tutorial I may have it wrong and it's multiplicative.
so if I understood correctly, and assuming I am very very careful with sample placement to really be in background areas, and avoid stars etc, is there any other downside to consider when using much higher tolerances (5,6, 8 etc)?
my other question is whether there's a downside to using more than one application of DBE on the same image, in terms of introducing noise or some other effect ...how far to you push it with one application vs 2 applications or more?
jeff
