In your videos when doing cosmetic correction during preprocessing you check the Auto detect but not check Use Defect list and instead do a bad pixel map using image container after calibration. What is the difference or is there a difference if I also check Use Defect list after adding my bad columns. Is this just a personal preference or does it produce different results?
