Missing FITS Info Question
edited December 2021 in PixInsight
Hi.  I may have asked this previously but I'll ask again.  Was using PCC to color calibrate and image and it would not plate solve.  Tried to use Image Solver and got the same error.  I checked the FITS header info in the combined RGB file after Channel Combination and there was no information.   There was also no FITS header info in the R,G,B Masters.  I looked at an individual Luminance sub exposure which did have FITS info, I took OBJECT RA and OBJECT DEC info from that file, used in PCC and everything worked fine.   Still puzzled as to why the FITS info would be missing from the Integrated Master R,G,B and combined files (done thru Channel Combination); it's the second time I've run into this issue.  Have you seen this problem?  Wondering if I missed doing something in pre processing.
  • Keep on eye on cloned images (or copies of previews). I am pretty sure FITs info does not carry forward form them. You should be able to determine at which point the FITs header goes away regardless of the above idea.
  • FYI - backtracked and discovered that when I used Normalized Scale Gradient on the data after Star Alignment, the FITS Header was changed and the information was removed from the data.  image
  • FYI - figured out what I did wrong.  Somehow, I'd inadvertently checked the "Overwrite Existing Files" when I ran the NSG script.  That destroyed the original data in the FITS header as is advertised.
  • Ah ha! Interesting.
  • Hi Reggie,
    So... I connected with John Murphy. You might have discovered a bug. But he can't figure out how it happens exactly. The condition you describe can happen if the data was in the form of integers instead of floats.
    Was were the images you used XISF files that were outputted from StarAlignment? ( assume so... )
  • Yes. And I checked the files after StarAlignment and the FITS info was still there. It was only after using Normalized Scale Gradient that the FITS info came up missing.
  • If you can provide me with a reference and target image that demonstrate the problem, I will take a look.
    Regards, John Murphy
  • Hi John; sorry its taken me a bit to respond.  If you send me an email address, I will share the DropBox folder I share with Adam that contain 2 XISF files.  The registered file is output from the Star Alignment Process which still has all the FITS Header info.  The NSG file is the same registered file but now output from the Normalized Scale Gradient script and there is no FITS Header info.
    Reggie Jones
  • I have sent a message that contains my email address.
    Regards, John
  • Got it and shared the folder.  Let me know if you need anything else.
    Reggie
  • Hi Reggie
    The source .xisf file was in Integer 16 format.
    NSG reads in the image and then has to convert its internal copy of the image to floating point. There was a bug in this conversion - I had forgotten to copy over the FITS headers.
    This bug was fixed yesterday. See PixInsight forum post:
    Please try it with this new version and let me know if it works.
    John Murphy
  • Thanks John.  So, I'm was working on a different dataset today and followed my normal workflow with NSG; I checked the NSG files and the FITS information did come across as expected.  Looks like it all works.
    Thanks for taking the time to help resolve this.
    Reggie
  • Wait... how was this file an integer file??
    That is still amystery?
  • Hi Adam. I’m not sure I can answer that one. I’m not that well versed in file structure.
    Reggie
  • I think it is possible that this data was not calibrated by PixInsight. Was the image from TelescopeLive? Are these images calibrated by TelescopeLive?
    The first evidence of processing that I see in the FITS header is CosmeticCorrection (PixInsight 1.8.8-11)
    I think this might explains why the data has not been converted to floating point.
    If this is the case, the Integer - missing FITS header bug may hit many people. I will try to get this bug fix included in an update, rather than waiting for the next release.
  • Hi John - this was Telescope Live data.  Specifically from their 1Click bundled data of NGC 4372, the Dark Doodad nebula.  The data I get from them, whether it's an Advanced Request I made or like this the data is always calibrated by them.
    After I download and Blink through it, unless there is something really unusual with it the next step I take usually is with Cosmetic Correction.
    Reggie
  • I see.
    But I am still curious. The data must be registered using StarAlignment. The interpolation I would have though to result in floating point results?
