Hello Adam.-
Every time I register images in binx2 (before normalizing and integrating) black artifacts appear around most of the stars. Each image features different artifact patterns.
I'm sure this problem produces bad results for me when integrating the images.
It is possible it is due to the registered algorithm but it is not clear to me. When I use WWBP I put "pixel interpolation" in auto mode, and by default it uses laczos-3 as the algorithm in my case.
I don't know if I should use other algorithms, or what consequences that might have.
That is why I ask for your advice.
I attach a jpg with three different images of a specific area where you can see how these artifacts are different in each shot.
Thank you so much
