I am having issues with my flats in WBPP 2.2, and could use some help please.
When I run the .2” flats through without CFA scaling enabled, I get a completely unusable calibrated light. Clearly the flat is causing problems.
When I run the .2” flats through with CFA scaling enable, I get this error in the log: Error: Zero or insignificant scaling factor for flat frame CFA component 0. (empty or marginal master flat frame data?)
I get the same error when I run the .1” flats through both with and without CFA scaling enabled.
I do not get any errors, and am able to end up with a stacked, master light when I run WBPP without any flats.
I have attached the messed up calibrated light, WBPP logs for the .2” runs, and screenshots of WBPP. A .1 and .2" flat are at the dropbox link below. Any help is appreciated! Thanks in advance.
https://www.dropbox.com/sh/arg4a1zueoy81v0/AABKRA21FLMpKvmaeh50R6QBa?dl=0
Tim
Run 1 - Old: lights, flats, darks, bias = no issue
Run 2 - Old: lights, flats, darks, New: bias = no issue
Run 3 - Old: lights, darks, New: flats, bias = fail
Run 4 - Old: lights, darks, bias, New: flats = fail
So this seems to indicate that the flat is the actual problem. However, I'm not sure how to troubleshoot this beyond taking new flats... which I've done. I took them manually - histogram right in the middle. Still failed! And really, all the math in PM I ran doesn't support the flats being the issue. So confusing. Any suggestions?
