I have two datasets of M31, one set taken in September 2020 and the other in September 2021.
2020 set of 59 x 120s lights, 21 x flats, 20 darks, 50 bias; 2021 set of 51 x 120s lights, 23 x flats 20 x darks, 50 bias.
I want to process both sets of data and then register them for use in the Normalise Scale Gradient Script and then on to an integrated masterfile.
My problem is that in one set of data the Andromeda Galaxy is about horizontal, but in the other set it is about 70 degrees from horizontal.
I have calibrated each set of images using WBPP 2.2 and NSGScript successfully and have 2 integrated images but you can’t register and integrate two images.
I have tried loading both sets of registered NSG files in Image Integration but I end up with an image of two overlapping Andromedas at the different angles.
Any help would be appreciated.
