Please correct my statements below if they are not correct:
-Darks include Bias signal, therefore...
-Only Darks, (and calibrated Flats/Master Flat created with Flat Darks), not Bias, are required to create a Master Dark to calibrate Light frames unless...
---You are attempting to scale Darks taken at an exposure different from your Lights.
---You are calibrating Flats with Bias, which can be done with Flat Darks more reliably across different camera platforms anyway.
Basically I want to be sure that there is not some role in calibrating a Master Dark that is played by separate Bias/Master Bias, except as noted for scaling. In order to minimise potential issues, I am fine with keeping, and occasionally updating, Dark libraries for different exposure times, and shooting Flat Darks each time I shoot Flats. I am shooting with an ASI2600MC Pro CMOS camera if this information is helpful.
Is this correct?
I takes ~5 minutes extra to shoot Flat Darks after shooting Flats, so not a huge time savings, and I have heard (so much hearsay, but nonetheless...), that Bias shot on some CMOS cameras can be suspect.
When I go through the tutorials on all of the extra steps necessary to calibrate out bad columns, (create defect lists, save that somewhere where you can find it, remember to apply it every time...), I question which type of sensors are "well behaved", and at what extra cost.
Maybe I am missing something, or maybe I just lack sophisticated taste... ;-P
