In WBPP2.1 Star Alignment it offers in the Image Registration pop up box to do Distortion Correction.
In the separate process Star Alignment, this is greyed out; I guess unless you have a .csv distortion correction file. See attached.
Kindly (our HK word for please) comment on this.
Previously, in April/May I ran WBPP (2.0?) on the same raw frames (at 460mm FL) and clicked distortion correction in Image Registration popup. I had good registration and as I recall no distortions. I am sure I would have noticed, and I doubt NSG script would work if distorted. I deleted that data and have been reprocessing with WBPP2.1.2.
With WBPP2.1.2 (same data), and with distortion correction enabled, I definitely have distortion (not rotations) in multiple registered images. Same reference image both times.
Now I am wanting to go back to the WBPP2.1.2 debayered images and run Star Alignment for comparison. But no distortion correction seems available.
I do not want to go through the extra scripts steps you did in your Cosmic Canvas video NGC3981 Register Luminance because WBPP2.0 worked well. I am wondering if WBPP2.1.2 is handling registration differently for some reason or I made some mistake with ver 2.1.2.
Do you have any suggestion what I should check, or do again?
