Home
Discussions
Home
PixInsight
Sign In
Sign In with Vanilla Forums
Register
Sign In
Categories
Recent Discussions
Categories
1.5K
All Categories
1.4K
PixInsight
Dimensions of Photoshop
8
CCDStack
121
General
June 2021
Ivor Trueman
June 2021
BlockHead
Python script to extract pixels (Fundamentals - Image Int. Primer Pt.2 @19:28)
Ivor Trueman
June 2021
in
PixInsight
Would it be possible to get the python script mentioned in the Fundamentals - Image Integration Primer Pt.2 at approx. the 19min28sec mark?
I'm interested in extracting some (noise) values from my images, to look at their distribution...
Ivor
BlockHead
June 2021
I wrote this several years ago when learning Python... so forgive the amateurish code (it still is that way...just more complex).
#!python
#Usage:
# Reads the value at a particular pixel from a set of images.
# Generates a list of those values.
# Outputs a CSV file
# Also create a histogram graph
import numpy as np
from astropy.io import fits
import matplotlib.pyplot as plt
import glob
import argparse
def frange(start, stop, step):
i = start
while i < stop:
yield i
i += step
def main():
#Creation of the command line options and arguments
parser = argparse.ArgumentParser()
parser.add_argument('filefilter',help ='Use a wildcard to capture desired data files in directory. e.g. *.csv',action='store')
args = parser.parse_args()
#The file list constraint of the command line to identify all FIT files
filefilter = args.filefilter
FileList = []
for file in glob.glob(filefilter): #create a list of files from directory from command line
FileList.append(file)
pixelstack = []
bins = []
for i in range(len(FileList)):
ccd_image = fits.getdata(FileList[i])
ccd_image = ccd_image.astype(np.float64)
x = 2165
y = 2276
pixelvalue = ccd_image[y,x]
pixelstack.append(pixelvalue)
# print(FileList[i],pixelvalue)
with open('pixelvalues.csv', 'w') as f:
header = ('Filename,PixelValue\n')
f.write(header)
row = (str(FileList[i]) + ',' + str(pixelstack[i]) + '\n')
print(FileList[i]+' '+ str(pixelstack[i]))
f.write(row)
f.close()
#font formatting for the chart
font = {'family' : 'DejaVu Sans',
'weight' : 'regular',
'size' : 15}
plt.rc('font', **font)
#setup figure
plt.title('Histogram')
plt.xlabel('Pixel Value')
plt.ylabel('Frequency')
print(min(pixelstack),max(pixelstack))
for j in frange(min(pixelstack),max(pixelstack)+.03, 5):
bins.append(j)
plt.hist(pixelstack,bins)
plt.show()
return()
# This is the standard boilerplate that calls the main() function.
if __name__ == '__main__':
main()
Ivor Trueman
June 2021
Thanks Adam - that's really useful. I'm completely new to Python & Spyder, so it took me a while to figure out how to add 'astropy' & enter the file wildcards into the command line / modify the code for OSC fits, but it's working fine!
Many thanks
Ivor
Sign In
or
Register
to comment.
Forum Software Powered by Vanilla
Ivor
