Hello Adam,
I watched you new videos on NSG and ran into a problem when running the script. I have LRGB data, choose to run the Lum registered data. Set all the parameters via your video. Made sure I set the output directory. Ran the script, started processing and came up with the following error. File I/O error, unable to create file Win 32 error (3), cannot find the path specified. What is really weird out of the 58 Lum files 38 worked and 20 failed. I then tried it with the Red images and they all failed.
Any thoughts, thanks.
Ed Stuckey
