I just watched the NSG script videos and I plan to start testing this technique on my data. I am excited, as you are, because of the photometric approach to data normalization. As for the gradient subtraction, however, I was wondering if you had compared Local Normalization to the NSG. In principle, both methods try to solve the same problem: large-scale inhomogeneity of the sky background and how it affects proper data normalization. In the NSG case, the inhomogeneity is removed (mostly) and then data is photometrically normalized, In the LN case, normalization is evaluated on a patch basis. It obviously still suffers from the noise bias that you mention in the videos but I was curious to hear your thoughts.
Thank you!
Luca
