Like many beginners, I'm starting off with a OSC (ASI294MC Pro) and I've seen discussions in other threads relating to the fact that may of your tutorials treat LRGB as the 'Standard' way to process data. Like many, I aspire to owning a set-up with a mono camera and filterwheel so it feels like getting to grips with working in this way probably makes sense. I've worked my way though quite a few tutorials and seen that you use LRGB most of the time but its now I've tried Deconvolution that I've really started to wonder if taking the 'easy' route of just working on combined RGB data is the right thing to do.
That being said, there are different ways to go about this, some making smaller steps in that direction, which of the following would you suggest (I'm currently shooting mainly galaxies in broadband due to already having a Celestron C8 if that makes any difference):
- Carry on processing in RGB (but work out what problems that may cause e.g. using deconvolution and then build an appropriate workflow)
- Pre-process in RGB but create a separate L image to post-process with
- Pre-process in RGB but split into R, G, B & L images to post-process with
- Split subs into R, G, B & L images and process from scratch as separate images
Thanks for any guidance, I want to make sure I start out on the right path from the outset!
Grant
