I just joined your PI Fundamentals and looking forward to the series. I have been using PI about a year and found bits and pieces of information on "Save Project", but never any comprehensive description in a forum or online. Could you advise if one of your videos gives a pretty comprehensive overview? I want to start there with the videos. I have used Save Project, and find it useful to pick up an continue my processing, but really don't understand much about it.
For my bits and pieces Save Project question... When running script WBPP, the output files are saved in directories, ie calibrated, registered, etc. After running WBPP, if I Save Project, are all these files saved again? I know WBPP saves it's own settings automatically.
Maybe a better way to ask... If doing calibration manually, and I have the output files such as calibrated, cosmetic correction, debayer, registered, etc saved on my drive. If I then Save Project, will all those files be saved again, using more disk space?
I assume a bundled project means it saves all the items checked in Project Generation. If correct, then what is a non-bundled project!?
Best Regards,
