FastTrack Data Bias Frame : found a black bar in one of the bias file
I haven't seen this posted yet.
running through the Open One image in PixInsight found that Bias file Target_1_0sec_1x1__0007.fit file has a varying thickness bar from left to right.
Using blink it's easy to see which files should be rejected.
(Also is this where one posts tutorial discussions?)
Cheers
  • HI Michael,
    The FastTrack table has two columns. The one on the left is the "training"...the column of links on right are the discussion sections. (I was hoping the arrow between them would direct you... ).
    True, rejecting the frames would be OK...but as a matter of math- these issues only appear in two out of 50 biases. Simply more forward with the understanding the values will be rejected is a good lesson to know.
