Hello Adam,
I recently subscribed to Horizons and had not got to any of your Ha blending techniques, but I did try your StarNet blending fixing star halos later in my workflow which I will get to later in my post.
Last year I captured about an hour of integration time on NGC 281 with an OSC while I was killing some time waiting for my primary target. The data was rather weak so last week while I was killing time waiting for my primary target to rise, I collected 5 hours over two nights of Ha on NGC 281 that I planned on blending with the OSC data from last year. I took the Ha data with my mono CCD camera. I decided to give Vicent's Ha blending using a continuum map a try. I was able to successfully do the first part which was the continuum map but I did 6 iterations because my RGB was weak. The second part which was transferring the a/b lab channels of the HaRGB from the continuum map method to an HaGB image did not work out for me because I think my Ha was too strong so I just resorted to separating the Lum channel from my HaRGB and blending the extracted lum channel with with a starless Ha using Screen. Then I processed the Lum and RGB (HaRGB) as per the standard work flow. I am curious to know your thoughts about Vicent's blending technique and if you have tried it.
You can see the original RGB there as well. So after dong the LRGB combine which I did soft stretches on before combining, I then used your Blending with StarNet and star halo removing technique. It took me several tries to get something somewhat acceptable and still had some yellow cast around the yellow/orange stars that I had to clean up using ColorMask and desaturation. This was even after doing a 50% screen blend. Just curious to know what you might think about my efforts in using this technique.
The RGB data in this image is sub par for me but it was a good exercise in learning new techniques. The main issue I had with the StarNet blending with halo fixing technique is doing that in a field with nebulosity. If the RGB was deeper I think it would have been more difficult or perhaps not appropriate to do. I was going to ask you what you did for nebula images but then I realized I can just watch your Horizon processing examples. I see you have some nebula images there but I had not had a chance to watch them yet as I am still going through your standard Horizon lessons. Thanks a bunch.
