Hello Adam, I am following Cosmetic Correction lessons step by step and have an issue when I should convert the defect map using "Pixel Math". In my case Pixel Math process fails when applied to binarized hot pixel defects map showing the error you can see in the attached picture. So I tried to invert the map using "Image - Invert" but no hot pixels were removed after following "Defect Map" process was applied.
Any suggestions?
Best
Max
