I tried StarNet several times with so-so success. I tested it on two images- Crescent nebula and the Needle Galaxy. The difference for testing purposes was mainly because the Crescent image has a ton of stars and the Needle Galaxy has few. So, I understand to use StarNet early on but I used it only on a mildly stretched image in an attempt to preserve the star color and create a star mask to add the stars back later. So far, this was fine in both cases. I then continue to process the starless images and finally add the stars back in using PixelMath. In the case of the Needle Galaxy it worked fine. The Crescent nebula was a disaster because the starless crescent still had a ton of star remnants that came out like ugly noise in the background. I attempted to use CloneStamp to clean it up but that did not work well. So, I am obviously doing something wrong. Any suggestions?
