I carefully followed your suggestions for setting up PI to produce my flats. I'm using an FLI ML16200 camera and used a flat panel to create the Lum_Flats (using 1.33 seconds and 30,000 ADU).
I went and calibrated my M13 light subs with only the Lum Master Flat I produced from the above settings (no Bias or Dark masters) - just wanted to see if the Flat would remove the dust motes. The Integrated image I got was one that is seriously over corrected. Do you know what would cause that?
