Much ike the prior person who posted, I also have avoided BPP (and the newer weighted BPP) and don't mind going through the individual steps manually (besides the feeling of control, it also serves as a teaching tool by reinforcing for me what is actually happening to the images one step at a time). I have been using SFS, using a formula like the one you showed for WBPP, but of course using SNRWeight rather than SNR, since that is what is available in SFS:
(a*(1-(FWHM-FWHMMin)/(FWHMMax-FWHMMin))
+ b*(1-(Eccentricity-EccentricityMin)/(EccentricityMax-EccentricityMin)) + c*(SNRWeight-SNRWeightMin)/(SNRWeightMax-SNRWeightMin))+P
If some of one's images have the issue you highlighted in Part 4 (ie, the SNR weight being erroneous due to imaging lower in the sky or thin clouds increasing the brightness of the image), is it possible to incorporate your formula for an "improved" SNRWeight based on Stars (ie, 1/(Math.abs(Math.min(StarsSigma+1,0))+1) * SNRWeight) into the above formula (replacing the SNRWeight portion) for a better result? Could I just replace each term of SNRWeight with the "fix" formula? Or would that mess up the syntax? If it is possible, could you provide the syntax of the new formula? Hope that makes sense.
On another note, an idea I have read elsewhere is to vary the constants a, b, c, and P in the SFS formula based on the type of DSO; eg, 5, 10, 20, and 65 respectively for nebulae; 20, 15, 25, 40 for galaxies; and 35, 35, 20, 10 for star clusters. Do you have any opinion on the merits of such an approach?
Thanks. Your videos are endlessly informative.
Ed
< 5.5 && Eccentricity <0.7 && Stars > ...350 <... (the limits are 2 sigma)
(5.5., 0.7 and 350 are variables and a function of the quality of the frames)
