When I do an image cal typically on more than 20 frames in some cases there will be 2-3 frames where the dark frame is incorrectly subtracted. I am using a master dark with the exact same time as my light frames, and this happens only when I have "Optimize" checked. When I look at the process console I notice for these incorrectly calibrated frames that the weighting factor is way off sometimes it is 0, other times it is more than 1.5, whereas on the correctly calibrated frames the weighting factor are all typically between 0.95 and 1.03. I learned to look at this from Adam's tutorial, very helpful. If I uncheck "Optimize" then all frames calibrate fine. I would like to understand why I get these incorrectly calibrated frames when "Optimize" is checked.
Khushrow
