ImageBlend script doesn't appear in menus after install.
I'm not sure what I've done wrong here. I've just switched from PC to Mac and I have successfully installed many updates/repositories. But ImageBlend doesn't appear in the Script menu after following the usual process.
I've done "Check for Updates" but none are pending.
Anybody know what I've missed?
Thanks, Jim
  • edited June 28
    Does imageblend appear in your PixiInsight/src/scripts/CosmicPhotons directory? If so you can probably add it using the Feature Scripts facility. If not then you can use Reset Updates to force a reload of everything in your repository list.
  • edited June 29
    Yes, it was in that directory and I added it with the Feature Scripts facility.
    Thank you, Jim
