GDay All
I dont expect an answer with this but maybe your thoughts and experience would be appreciated. I went from a ZWO2600mono APS-C to a brand new ZWO6200 mono full frame camera. I also now have a larger new FW and 50mm unmounted LRGBSHO filters. The APO is an Askar FRA500 petzval scope. My scopes adapters screw straight into the filter wheel which secures the camera etc. Ie 54mm straight to 68mm so no obstruction. Dark rings came with the gear and they are also used. I used a mask and gloves to install the filters and to screw the FW to the camera so no smudges on the camera sensor or filters. The adapter from the OTA does no hit the filters; which I tested prior to assembly.
I thought I do a light test with a 5min dark frame. All good. Then I took some flat frames to see how much vignetting I would get. Well, looks as if I took X-Rays of some ones fingers. More prominant in Ha and Sii. So I thought light getting in here maybe; covered everything and no light leak. I took flats with a trace pad; had to be the pad so I purchase a Giotto Flat Field generator..still weird patterns. Ah lets get some sky flats; still weird patterns.
So, I turned the Giotto the other way up, still the weird pattern and in the same direction. I also turned my scopes captain wheel around; took flats and the weird pattern is still in the same direction. Tried different gains as well, still the same pattern. Tad strange as the specs of this camera are basically the same as my previous camera and I never saw these patterns. I did manage 5min subs with each filter aimed at Carina. Due to weather I have not been able to get a few more. I have contacted the shop and linked files and await an answer. I also posted on the ZWO forum..must be in the too hard basket as no response. My concern is will these flats corrupt a final image? Flats taken at EAF focus. Id like to pick your brain if you have time. Regret long winded post. I know you are a busy man and dont expect a reponse.
I have one drive links to my Carina lights, sky flats and flat frames if you want to have a gander and have time.
Regards
