Local Normalization
edited June 4 in PixInsight
I was watching the Local Normalization video in Fast Track and noticed the files that were selected had the post fix of_c_d.  Mine have _c_cc_d_r ... did I select from the wring directory?
Wayne Hensley
  • No.. you did it correctly! Darn it.. did I make that mistake? It may have been I was showing something I had already done (like a cooking show). You definitely should be normalizing the registered frames.
    Can you show me video and timestamp it happens?
    -The Blockhead
  • Hmmm... I just looked back at this video..and it appears OK to me...
  • Oh... I think I now understand the confusion.
    *SIgh*
    the post fix was _c_d_R  <- ... the R was what I was worried about.
    The "cc" that you have is because you listened to me and ran using the template for cosmetic correction and not the automatic one in WBPP. If you use the automatic one in WBPP you will *not* have "cc" in the file name. It is considered part of calibration because that method uses the dark frame.
    I hope this is clear. I believe I have the full story now.
  • Thank you sir!
    Wayne
