Multiscale Gradient Correction
Trying to use Multiscale Gradient Correction process in PI on a master image of M101. As per PI’s instructions for MGC, I first attempted to use SpectrometricFluxCalibration on the image, and received the error message below. I have no idea what this might mean. Both my Gaia files and MARS files are up to date. Any thoughts appreciated.
Doug Davis
Error: Invalid Gaia DR3/SP XPSD server execution: Couldn't Error: Invalid Gaia DR3/SP XPSD server execution: Couldn't retrieve a valid spectrum wavelength table.
<* failed *> a valid spectrum wavelength table.
<* failed *>
  • Typically this means you associated the regular DR3 files with the GAIA process instead of the DR3/SP files.
    If you take screenshots of the the GAIA process... using the wrench- make certain you associated the correct files with DR3 and the DR3/SP.
