I may have a habit I need to break.
When I'm shooting at high ISO with my DSLR, I usually do my noise reduction pretty early in my processing. Since Noise Reduction inherently softens an image, I want to know how much sharpness I'm going to need to bring back.
I notice that in most of the PixInsight processing, people are doing the noise reduction near the very end of their processing. Why? I'm guessing it is because when you do noise reduction, the smoothing algorithms are essentially altering the data and if you do that up front, you are changing data that you might want to preserve for other processes. It looks like some of the processes also act to reduce noise so if you do your noise reduction at the end, you don't need to be as aggressive about it.
So those are my guesses, what is the real reason?
From your two responses (this one and the one about Linear/Stretched), I can see why you really want to to wait with the noise reduction for the astronomical images. The signal to noise ratio for the astronomical images is MUCH lower so I have a much higher risk of losing signal if I do the noise reduction early. For the vast majority of my DSLR work, the risk of losing signal by early noise reduction is fairly insignificant.
I just need to adjust my thinking here a little.
Thank you for the response.
