SELECTIVE REJECTION PIXINSIGHT
I recently photographed the galaxy IC 342 but I noticed that in the green channel I find spikes in the background on half of the frames.
I performed the SELECTIVE REJECTION method but clearly I find the repaired part noisier.
I wanted to ask you if in the image integration settings I can overcome this problem by modifying some rejection parameters in PIXEL REJECT 1/2 AND LARGE SCALE PIXEL REJECTION.
in attached the images
CS
riccardo
1835 x 844 - 483K
503 x 1168 - 127K
  • Yeah... the issue is the number of bad frames is a significant number of the good frames...so the integration of the good frames will necessarily have a worse S/N. This is just physics and math. There isn't a whole lot you can do about it. Later NXT will help since it does operate on the image in a tiled manner.
  • thanks Adam for the very quick reply!
    today I had an idea.
    I created 2 master greens: one made of all the frames, the other made only with the frames without the spike.
    Then I performed your trick on the scattered lights.
    I took the background with the spike and used it as a reference to the tgt background, then I gave a slight increase in noise and replaced the defective part. the result is perfect
    clear skies
    Riccardo
  • OK! Great work!!
    That will help equalize the noise.
    Way to think like a blockhead...lol
