Hi all,
I am having an issue with what looks like the central obstruction showing up in calibrated and stacked subs and I am not sure what is causing it. I believe my flats and bias files are ok, but with the processing for a reflection nebula it appears I am pulling out something so I am doing something wrong. (Witchhead in this case). I have a Rasa 8 with the 2600MM Duo. Any ideas? I used the Elumiglow flat panel. I attached the stacked subs (shows on 30s and 120s) this picture is from Blue filter (Baader) though I also see it on the Antilia rgb tri band I used for lum. I also attached the master flat and a single one. (snippet, let me know if I should post the original files). I used Nina Flat wizard and set the target at 40% for exposure.
processing wise,, I am in a Bortle 6 and working on the CN challenge which is a reflection nebula so the steps leading to the attached is: spectophotometricfluxcalibation, multiscalegradientcorrection, starxterm and then ghs.
Any ideas?
