I purchased a larger apo refractor recently and decided to attempt another composite M31 image using missing values construct per Adam's tutorial. I shot 35 3 minute subs at 180" and a like number of subs at 15". I processed each stack using CCD Stk and then refined both images using Photoshop extended plus a few plugs ins. I normalized both images with the 180" image on top. The resulting weights approximated the exposure ratio. I used 40,000 to 100,000 to create the missing values range. I also did a 5 pixel grow but whne I finally did the combine operation, the nucleus area was distinctly brighter than the abutting area at 180". Should I have not processed the two images through PS CS6 extended before running the missing values construct? I tried to up the minimum value restrict range to 45000 and 55,000 but that failed to remedy the mismatch. Any thoughts would be welcome.
Frank P.
