If you look at the full res view of https://www.astrobin.com/8opil7/F/ t
here are a good many extremely faint background objects (particularly at the bottom of the image) that might pass for stars or galaxies and are slightly more visible here:
The processing was done using modifications of your 08-26-22 OSC Globular Cluster video series. However, at the end of the initial processing, these objects were quite blotchy and spoiled the image as shown here:
It was very difficult to remove or minimize these objects. I tried unsuccessfully removing them with NXT and/or isolating them with a mask using e.g., MLT, Binarize or STF. Eventually, I generated star and starless images with STX and then adjusted and re-blended them using a "Screen" instance of the Image-Blend script. The resulting image which I used for Astrobin wasn't perfect but significantly improved.
I have several questions. First, are these simply processing artifacts or highly blurred real structures?
Second, if they are artifacts, how can they be avoided or more fully removed than I did?
Last, what is your critical assessment of my final Astrobin image?
Thank you,
Michael
