WBPP Meta Data Errors
I am running most recent PI and WBPP 2.7.8.  When WBPP script is run and files calibrated and then run through Subframe Selector the following errors are posted:
** Warning: Noise estimates are not available in the image metadata and are being calculated from possibly non-raw or uncalibrated data. Image weights can be inaccurate.
** Warning: PSF signal estimates are not available in the image metadata and are being calculated from possibly non-raw or uncalibrated data. Image weights can be inaccurate.
** Warning: Noise scaling factors are not available in the image metadata and are being calculated from possibly non-raw or uncalibrated data. Image weights can be inaccurate.
Stars detected:    643
Valid PSF fits:    643 (100.00%)
When I run the same files through Image Calibration manually and then run them through Subframe Selector, no errors are posted.
Any idea why the WBPP script is not performing the "Signal" and Noise Evaluations" and  posting the metadata into the calibrated files?
I see no setting for this in the script that I can verify.
Bill
  • Please search for this on the official Pixinsight forum.
    I believe I saw mention that this is a bug (and either was fixed or will be fixed... I do not know if you are up-to-date).
    I believe WBPP is actually doing everything correctly...but the warnings are the bug.
  • As far as I know I am up to date.  I noticed this happening on a friends fresh installation yesterday over Zoom, so the bug has not been sprayed yet.
    Bill
  • Yeah...OK. Again, this is from memory. Please check the official forum..I am pretty sure I saw a note about this.
