I'm having a problem with donuts, some fairly severe. Here's what I tried so far:
Changing the camera
Changing the filter
The donuts show up in the same number, at the same positions for each experiment.
The scope is a Sharstar SCA260 f/5. It is a Cassegrain astrograph, it has a primary mirror, a secondary mirror, and a set of lenses in front of the focuser tube.
The only other thing in the imaging train is an OAG, which I will try to eliminate next.
I have tried racking the focuser all in, and cleaning the back of the rear lens.
The question: can dust or debris on a mirror cause these artifacts? When I used the calculator at astronomy.tools, it informs me that the dust particles are between 1 and 1.5 mm from the sensor. But this doesn't make sense since it is the same with different cameras (same sensor size).
The flats don't calibrate these out, and I don't understand why. Instead, it leaves a subtle but ugly mottling on the stacked images. The donuts are barely visible in the flats themselves. I'm taking exposures at the same gain. I've tried both flat panel and sky flats.
What do you think my options are at this point?
Wes
