Up to this point in my journey to learn PI...no problem thanks to your excellent tutorials. While trying to update my current version of PI 1.8.9-1, I keep running into this problem (see attached file). The problem has been noted on the PI forum by another member, but PI was unable to reproduce the error. Any ideas on how to proceed from here? I was able to reinstall PI 1.8.9-1 with no problems. Unfortunately, it appears I need an updated version to take advantage of SetiAstro scripts. Thank you for your help. George
The "Unable to locate entry point" error typically occurs when an application, like PixInsight, tries to access a function or resource in a dynamic link library (DLL) that isn't available. This can happen due to:
Steps to Troubleshoot:
If the problem persists, checking PixInsight's forums or support might provide a solution specific to the version or setup in use.
