I was stumped when I took some flats and they showed a relatively even field instead of showing some vignetting. It took me a few days to figure out that I used the wrong function in SharpCap and the flats were calibrated by a master flat and ended up being unusable as they were. In addition since I used the normal capture function in SharpCap instead of the Flats function, the files had the FITS keyword OBJECT which caused them to be unusable in WBPP without removing the keyword, since I was processing by OBJECT. WBPP wasn't going to use the Flats anyway to calibrate my lights, which were of multiple objects.
I decided I might be able to use Pixelmath to multiply the two images, as I remembered that Adam had said that Lights were divided by Flats and a scaling factor was used. I tried rescaling the result but the resultant image was at the .2 level in the center and I know I was hitting the middle of the histogram when I took the exposures so the resultant flats should be roughly around the .5 level. Can I scale the result arbitrarily, or is the scaling factor used in calibration a function of the statistics of the two images used in the division?
