Hello Adam,
I am a FastTrack user and have been following the videos and updating my WBPP configuration choices. I have used PI and WBPP for a couple years, and am seeing some improvements in the master lights, but also have experienced some major issues.
On May 29th I processed 90 120s lights with accompanying flats and dark flats. I used an ASI2600MC Pro which has almost zero amp glow so I skipped including any darks. I shot the images with two different filters (Askar C1 & C2 - 45 subs each) so I used the FILTER keyword and has WBPP set up to create two master lights.
I am attaching a ZIP with several files that hopefully will help you see what happened. Reviewing the log, I see at the 15:16:58 mark that WBPP complete the Debayer step with 90 succeeded, 0 failed, and 0 skipped.
What I see next in the log I believe is the Local Normalization, but I see no errors as the cache was created successfully. At 15:16:59 I see "End demosaicing of light frames" and then nothing more.
One of the screen shots shows the process monitor with the message "Abort Requested" ... but I had not touched the PC to make such request. In fact, I let the machine run for several hours and saw this when I returned. The Windows task manager showed PixInsight as active but using 0% CPU.
Any help would be very much appreciated ... thanks,
Richard
                  zip
                  zip
