I shot pictures of M51 with the Moon at Zenith in a Bortles 6 environment two weeks ago using a 90mm APO refractor, an Astronomik L-3 filter and an SBIG 8300 OSC imager. 2 hours of subs @ 180" per image, darks, flats and biases. Excellent guiding at least as charted by PH.D ver 14.1.
I used Adam's OSC process doing calibration in CCD, then debayering into separate LRGB sets. So far so good. When I went to the registration step on each color set. Lum and green worked well using the PS plug in Adam recommends but blue and green would not register even without the high precision setting. The other native CCD Stack registration tools failed as well. Tried to process each color set in Deep Sky Stacker - Lum and green - yes; Red and Blue no. Finally stepped through the processing sequence in CCD Stack with the plug in and from frame to frame I got wild rotation and frame to frame jump for blue and red subs.
Had this happen once before but attributed it then to Murphy paying me an unwanted visit. Any thoughts from the Block community would be deeply appreciated.
Frank P
